Hi All,
I’m writing a python script for Shaft reinforcement, I’ve 04 rebars sets (02 vertical sets for outside and inside faces and 02 circular sets for outside and inside faces)…for this, I defined 04 containers where I can fill them with each rebar sets (Note: I choosed to set a single transaction regrouping all rebar sets and any suggetion for a better organization will be welcomed )
My containers are defined correctly but I’m stuck how to set correctly the for loop of the Ilist curves to be able to arrange my rebars into 04 sublists so they can match the containers range, for that I’m getting the following error:
For more details, please check my references below:
**1st script: Dynamo Curves**
import sys
import math
from Revit.Elements import Element
element = IN[0]
cover = IN[1]
circular_bar_type = IN[2]
vertical_bar_type = IN[3]
spacing = IN[4]
geo = element.Geometry()
surfaces = geo[0].Explode()
s_area = []
for i in surfaces:
s_area.append(i.Area)
S_area = ["%0.2f"%(round(i,2)) for i in s_area]
surf = []
surf_area = set()
for s, a in zip(surfaces, S_area):
if a not in surf_area and S_area.count(a) == 2:
surf.append(s)
surf_area.add(a)
#getting circular curves
out_cir_crv = surf[1].GetIsoline(1, 0).Explode()[0]
iner_cir_crv = surf[0].GetIsoline(1, 0).Explode()[0]
#getting vertical curves
out_V_crv = surf[1].GetIsoline(0, 1).Explode()[0]
iner_V_crv = surf[0].GetIsoline(0, 0).Explode()[0]
# overlap lengths
circ_overlap_length = circular_bar_type.GetParameterValueByName("Diamètre de barre")*50/1000
V_overlap_length = vertical_bar_type.GetParameterValueByName("Diamètre de barre")*50/1000
# cover from side face to circular rebar centerline
cir_cover = circular_bar_type.GetParameterValueByName("Diamètre de barre")/2000 + cover
# cover from side face to vertical rebar centerline
V_cover = 2* cir_cover-cover + V_overlap_length/100
# circular curves for outer and inner sides
out_cir_crv = out_cir_crv.Offset(-cir_cover)
iner_cir_crv = iner_cir_crv.Offset(cir_cover)
# total circular rebars length for outer and inner sides
out_circ_path = out_cir_crv.Length + circ_overlap_length
iner_circ_path = iner_cir_crv.Length + circ_overlap_length
# circular rebars count for outer and inner sides
out_rebar_count = math.ceil(out_circ_path / (12 - circ_overlap_length))
iner_rebar_count = math.ceil(iner_circ_path / (12 - circ_overlap_length))
# circular remainder distances for outer and inner sides
out_rest_length = out_circ_path - out_rebar_count * (12-circ_overlap_length)
iner_rest_length = iner_circ_path - iner_rebar_count * (12-circ_overlap_length)
# angle for rebar length = 12 for outer and inner sides
out_rebar_angle = 12 * 360 / out_cir_crv.Length
iner_rebar_angle = 12 * 360 / iner_cir_crv.Length
# circular overlap angles for outer and inner sides
out_circ_overlap_angle = circ_overlap_length * 360 /(2* math.pi * out_cir_crv.Radius)
iner_circ_overlap_angle = circ_overlap_length * 360 /(2* math.pi * iner_cir_crv.Radius)
Start_angles = []
End_angles = []
st_angle = 0
end_angle = out_rebar_angle
for i in range(0,int(out_rebar_count)-1):
star_angle = st_angle + i * out_rebar_angle - i* out_circ_overlap_angle
Start_angles.append(star_angle)
End_angle = end_angle + i * out_rebar_angle - i * out_circ_overlap_angle
End_angles.append(End_angle)
out_rest_angle = (out_circ_path - out_cir_crv.Length) *360 /(2* math.pi * out_cir_crv.Radius)
out_Arc = []
rest_Arc = []
L_out_arc = 0
k = 0
for i, j in zip(Start_angles, End_angles):
out_arc = Arc.ByCenterPointRadiusAngle(out_cir_crv.CenterPoint, out_cir_crv.Radius, i, j, Vector.ZAxis())
out_Arc.append(out_arc)
L_out_arc += out_arc.Length
k += 1
Rest_arc = out_circ_path - (L_out_arc - k * circ_overlap_length)
rest_Arc.append(Rest_arc)
star_angle_rest_arc = End_angles[-1] - out_circ_overlap_angle
a = out_cir_crv.Length
b = 12 - circ_overlap_length
if round(a % b, 2) == 0:
rest_arc = 0
rest_arc = Arc.ByCenterPointRadiusAngle(out_cir_crv.CenterPoint, out_cir_crv.Radius, star_angle_rest_arc, out_circ_overlap_angle, Vector.ZAxis())
out_Arc.append(rest_arc)
Start_angles = []
End_angles = []
st_angle = 0
end_angle = iner_rebar_angle
for i in range(0,int(iner_rebar_count)-1):
star_angle = st_angle + i * iner_rebar_angle - i* iner_circ_overlap_angle
End_angle = end_angle + i * iner_rebar_angle - i * iner_circ_overlap_angle
iner_rest_angle = (iner_circ_path - iner_cir_crv.Length) *360 /(2* math.pi * iner_cir_crv.Radius)
iner_Arc = []
rest_Arc = []
L_iner_arc = 0
k = 0
iner_arc = Arc.ByCenterPointRadiusAngle(iner_cir_crv.CenterPoint, iner_cir_crv.Radius, i, j, Vector.ZAxis())
iner_Arc.append(iner_arc)
L_iner_arc += iner_arc.Length
k += 1
Rest_arc = iner_circ_path - (L_iner_arc - k * circ_overlap_length)
star_angle_rest_arc = End_angles[-1] - iner_circ_overlap_angle
c = iner_cir_crv.Length
d = 12 - circ_overlap_length
if round(c % d, 2) == 0:
rest_arc = 0
rest_arc = Arc.ByCenterPointRadiusAngle(iner_cir_crv.CenterPoint, iner_cir_crv.Radius, star_angle_rest_arc, iner_circ_overlap_angle, Vector.ZAxis())
iner_Arc.append(rest_arc)
out_direct = out_V_crv.Direction
iner_direct = iner_V_crv.Direction
if out_direct.Z > 0 :
out_V_crv = out_V_crv
out_V_crv = out_V_crv.Reverse()
if iner_direct.Z > 0 :
iner_V_crv = iner_V_crv
iner_V_crv = iner_V_crv.Reverse()
out_vect = out_direct.Cross(Vector.ByCoordinates(0,1,0))
iner_vect = iner_direct.Cross(Vector.ByCoordinates(0,-1,0))
out_V_crv = out_V_crv.Translate(out_vect, V_cover)
iner_V_crv = iner_V_crv.Translate(iner_vect, V_cover)
v_path = out_V_crv
out_V_crv = out_V_crv.ExtendEnd(V_overlap_length)
iner_V_crv = iner_V_crv.ExtendEnd(V_overlap_length)
out_path = Circle.ByCenterPointRadius(out_cir_crv.CenterPoint, out_cir_crv.Radius - V_cover + cir_cover )
iner_path = Circle.ByCenterPointRadius(iner_cir_crv.CenterPoint, iner_cir_crv.Radius + V_cover - cir_cover)
OUT = out_Arc, iner_Arc, out_V_crv, iner_V_crv, out_path, iner_path, v_path
**2nd script: Rebars creation**
import sys
import math
import System
from System.Collections.Generic import IList, List
clr.AddReference('RevitAPI')
# Dynamo curves
out_cir_crv = [i.ToRevitType() for i in IN[0][0]]
iner_cir_crv = [i.ToRevitType() for i in IN[0][1]]
out_V_crv = IN[0][2].ToRevitType()
iner_V_crv = IN[0][3].ToRevitType()
out_path = IN[0][4].ToRevitType()
iner_path = IN[0][5].ToRevitType()
v_path = IN[0][6].ToRevitType()
cir_bar_type = UnwrapElement(IN[1])
V_bar_type = UnwrapElement(IN[2])
Start_Hook = UnwrapElement(IN[3])
End_Hook = UnwrapElement(IN[4])
host= UnwrapElement(IN[5])
H_s = IN[6]/0.3048
V_s = IN[7]/0.3048
rebar_type = [cir_bar_type, cir_bar_type, V_bar_type, V_bar_type]
container_name = [i.ToDSType(False).Name for i in rebar_type]
St_Hook = [End_Hook, End_Hook, Start_Hook, Start_Hook]
end_Hook = [End_Hook, End_Hook, End_Hook, End_Hook]
#cir_container_name = cir_bar_type.ToDSType(False).Name
#V_container_name = V_bar_type.ToDSType(False).Name
# compute the rotation angle
def rebar_rotation(circle, space):
sweepAngle = (space * 360) / (circle.Radius * 2 * math.pi)
return sweepAngle
out_angle = rebar_rotation(out_path, V_s)
iner_angle = rebar_rotation(iner_path, V_s)
# rotated rebars count
out_count = int(math.ceil(360/out_angle))
iner_count = int(math.ceil(360/iner_angle))
# get rotated curves
circ_count = int(math.ceil((v_path.Length -0.1*0.3048)/H_s))
out_cir_curvs = []
for i in range(0, circ_count):
temp = []
for j in out_cir_crv:
e0 = 0.05*0.3048
e= e0 + i * H_s
circ_offset = Transform.CreateTranslation(out_V_crv.Direction.Normalize()*e)
j = j.CreateTransformed(circ_offset)
temp.append(j)
out_cir_curvs.append(temp)
iner_cir_curvs = []
temp = []
for j in iner_cir_crv:
e0 = 0.05*0.3048
e= e0 + i * H_s
circ_offset = Transform.CreateTranslation(iner_V_crv.Direction.Normalize()*e)
temp.append(j)
iner_cir_curvs.append(temp)
out_V_curvs = []
for i in range(0, out_count):
a= i*out_angle
rot_curv = Transform.CreateRotation(XYZ.BasisZ, a*2*math.pi/360)
out_curvs = out_V_crv.CreateTransformed(rot_curv)
out_V_curvs.append(out_curvs)
iner_V_curvs = []
for i in range(0, iner_count):
a= i*iner_angle
iner_curvs = iner_V_crv.CreateTransformed(rot_curv)
iner_V_curvs.append(iner_curvs)
curvs = out_cir_curvs + iner_cir_curvs + [out_V_curvs,iner_V_curvs]
#create horizontal line needed to create normal vector
out_line =Line.CreateBound(out_V_crv.GetEndPoint(0), iner_V_crv.GetEndPoint(0))
iner_line =Line.CreateBound(iner_V_crv.GetEndPoint(0), out_V_crv.GetEndPoint(0))
out_circ_vect = []
for i in range (0, len(out_cir_curvs)):
temp = []
for j in out_cir_curvs[i]:
star_pt = j.GetEndPoint(0)
end_pt = XYZ(0 , 0, star_pt.Z )
h_line = Line.CreateBound(star_pt, end_pt)
h_vect = (h_line.GetEndPoint(1) - h_line.GetEndPoint(0)).Normalize()
temp.append(h_vect)
out_circ_vect.append(temp)
iner_circ_vect = []
for i in range (0, len(iner_cir_curvs)):
temp = []
for j in iner_cir_curvs[i]:
h_line = Line.CreateBound(end_pt, star_pt)
temp.append(h_vect)
iner_circ_vect.append(temp)
rot_90 = Transform.CreateRotation(XYZ.BasisZ, math.pi/2)
out_line = out_line.CreateTransformed(rot_90)
iner_line = iner_line.CreateTransformed(rot_90)
#get rotated lines
out_V_Vect = []
a= i*out_angle
rot_vect = Transform.CreateRotation(XYZ.BasisZ, a*2*math.pi/360)
out_vect = out_line.CreateTransformed(rot_vect)
out_V_Vect.append(out_vect)
iner_V_Vect = []
a= i*iner_angle
iner_vect = iner_line.CreateTransformed(rot_vect)
iner_V_Vect.append(iner_vect)
#create normal vectors
out_V_Vect = [(i.GetEndPoint(0) - i.GetEndPoint(1)).Normalize() for i in out_V_Vect]
iner_V_Vect = [(i.GetEndPoint(0) - i.GetEndPoint(1)).Normalize() for i in iner_V_Vect]
Vect = out_circ_vect + iner_circ_vect + [out_V_Vect, iner_V_Vect]
# create rebars
rebars = []
containerTypeId = [RebarContainerType.GetOrCreateRebarContainerType(doc, c ) for c in container_name]
rebarContainer = [RebarContainer.Create(doc, host, r) for r in containerTypeId]
for i, j in zip(range(0, len(curvs)), range(0, len(Vect))):
totalLength = []
rebar_curv = List[Curve]()
for c, v in zip(curvs[i], Vect[j]):
totalLength.Add(c.Length)
rebar_curv.Add(c)
rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, rebar_type[i], St_Hook[i], end_Hook[i], host, v, rebar_curv, RebarHookOrientation.Left, RebarHookOrientation.Right, True, True)
doc.Regenerate()
rebarContainer[i].AppendItemFromRebar(rebar)
doc.Delete(rebar.Id)
rebar_curv.Clear()
quantityParameter = rebarContainer[i].get_Parameter(BuiltInParameter.REBAR_ELEM_QUANTITY_OF_BARS)
totalLengthParameter = rebarContainer[i].LookupParameter("Longueur de barre totale")
containerParameters = rebarContainer[i].GetParametersManager()
containerParameters.AddOverride(quantityParameter.Id, len(curvs[i]))
containerParameters.AddOverride(totalLengthParameter.Id, sum(totalLength))
rebars.append(rebarContainer[i])
OUT = rebars
Shaft_rebars.dyn (33.0 KB)
circular_wall.rvt (3.4 MB)
Any help will be appreciated
Thanks.
