Setting parameters in Revit error
the set parameter block is telling me I need to input an integer for the parameter type. The math floor block should be supplying an integer, but it is still giving me an error.
Can you show the actual inputs via the node preview bubbles?
Can you show the exact warning messages (for both nodes) as well? Would also be helpful to use an Object.Type node to confirm you’re providing integers.
The error is the same for both nodes. I also threw in an object node
It might be something else that’s causing an issue and it just happens to be returning this error. It would be more helpful if we could actually see all of the data you’re providing.
The data is inputted through a GUI as a string and into a list here is the list with the data
