From reading this I found that I can set my model curves to Sketch plane in my family (standard Adaptive family current) metric Meters but it does not work as i need it too when i try and code this using. Autodesk.Revit.DB.CurveElement.SetSketchPlaneAndCurve()
It says it requires 3 arguments not just 2 but all the documentation just asks for a SketchPlane and Curve as input.
They maybe other errors in the code i am still learning how to code Python in Dynamo/Revit
Crv = IN [0]
Skplane =IN[1]
# Place your code below this line
Autodesk.Revit.DB.CurveElement.SetSketchPlaneAndCurve(Skplane,Crv)
OUT = 0
File Here:SetSketchPlaneAndCurves Error.dyn (26.0 KB)
