SetParameter error: TypeError: Multiple targets could match: Set(str), Set(ElementId)
Hey everyone,
I have the task to set project paramters for the current Document.
What i did so far:
  1. Get the informations i need in 3 Lists
    • one list contains the elementID
    • one list contains the parameters i want to set
    • one list with the parameter values
  2. wrote a script that writes the parameter values in the right paramters to the right element. If i execute the script i get an error which said: “TypeError: Multiple targets could match: Set(str), Set(ElementId)”
I have no clue why i am getting this error because i used same script and it worked fine:
Greets
Dan
What it’s telling you is that one or more of your elements has a Parameter by the name your looking up that wants an ElementId as the value and not a string.
Check to make sure all of your elements have the Parameter with param type Text.
Hello @DanTheMan
in addition to @SeanP 's answer it will seem that you have null values in your Parameter values list
thanks so much
String from Object did the trick
I feel bad for opening the topic a again. :fearful: @c.poupin @SeanP
I worked on the script and after executing the script i got an error:
Warnung:IronPythonEvaluator.EvaluateIronPythonScript fehlgeschlagen.
File “”, line 38, in
AttributeError: ‘NoneType’ object has no attribute ‘Set’
It sets the Parameter for the first Element in the list and then i get this error
can someone help again? :disappointed:
hello
error indicates that a parameter with the given name was not found for this element
thanks for the hint. Found the problem.
  1. writes the parameters and takes this as an Input
  2. set the parameters and takes this as an Input
    of courese i changes the excel
idiot :man_facepalming:
