I want to set all sheet with a Guide Grid. I am stuck providing the proper value type to complete the script.
Thanks in advance, Patrick
Guide Grid parameter storage type is “Element ID” currently your feeding string. Below is the solution.
Thank you, you made my day!
Patrick
No Problem
Question - Is there a way to turn the Guide Grid off/on for all Sheets using the same script or does that need to be a new script all together
hello,
I have faced the same issue, tried this solution, but still the script didn’t work, below screenshot:
