Trying to set a Boolean Type Shared Parameter named “ASSET” but cannot seem to get a grip on how… The “ASSET” portion of the ELIF below and the commented code don’t work throws an error in any case:
# Default imports
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import * #################################
import Revit #################################
clr.ImportExtensions(Revit.GeometryConversion) #################################
clr.ImportExtensions(Revit.Elements) #################################
# Import DocumentManager and TransactionManager##################################
clr.AddReference('RevitServices') #################################
import RevitServices #################################
from RevitServices.Persistence import DocumentManager #########################
from RevitServices.Transactions import TransactionManager #####################
doc = DocumentManager.Instance.CurrentDBDocument #############################
elements = IN[0] ##Elements in the model ##EXPECTS STRINGS FROM EXCEL TO START
headers = IN[1] ##Headers for reference
data = IN[2] ##Data
###Initialize
out=[]
outMain=[]
outSub=[]
found=0
##Find "MARK" Position from headers
for markPos, mark in enumerate(headers):
if mark=='Mark': ##Found mark in headers proceed
found=1
break ##BREAK loop with current header index
if found==1: ##Consider adding additional parameters to key-in on other than mark
for element in elements:
emark=element.GetParameterValueByName('Mark')
for dat in data:
if dat[markPos]==emark:
outMain=[]
for hI, param in enumerate(headers): ##hI count based on header to corresponding data For parameters that are headers in the file
outSub=[]
try:
if param == 'ASSET_CONDITION': ###NEED TO LOOK AT TARGET PARAMETERS IN REVIT AND RESET THE TYPE ACCORDING TO THE TARGET PARAMETER DATA TYPE, INT, TXT, etc.
element.SetParameterByName(param,int(dat[hI])) ###Attempt set data header/param name, dat[i] corresponding data at index
outSub.insert(0,"Success!(INT)") ###If it succeedes report it
elif param == 'ASSET': ###NEED TO LOOK AT TARGET PARAMETERS IN REVIT AND RESET THE TYPE ACCORDING TO THE TARGET PARAMETER DATA TYPE, INT, TXT, etc.
outSub.append ("trying:" + param)
ele=UnwrapElement(element)
elementType = doc.GetElement(ele.GetTypeId()) ######################
parameter = elementType.get_Parameter(param)
parameter.Set(str(dat[hI]))
#ASSET = [a for a in doc.FamilyManager.Parameters if a.Definition.Name=='ASSET'][0]
#if dat[hI]=='1':
# doc.FamilyManager.Set(ASSET, 1==1)
#else:
# doc.FamilyManager.Set(ASSET, 1==0)
##element.SetParameterByName(param,int(dat[hI])) ###Attempt set data header/param name, dat[i] corresponding data at index
outSub.append("Success!(T/F)") ###If it succeedes report it
elif param == "Assembly Code": ##SPECIAL ODD-BALL CASE for SYSTEM TYPE PARAM (Assembly Code)####
ele=UnwrapElement(element) ##########
#Get the type ###################### (UNIFORMAT TYPE param)
# Get the parameter###################
parameter = elementType.get_Parameter(BuiltInParameter.UNIFORMAT_CODE)
#Set the parameter in a Transaction###
parameter.Set(str(dat[hI])) ##FROM THE current DAT line of DATA return the data from the hI Index position in the list
#Set the parameter end Transaction###
outSub.append("Success!(UNI)")
element.SetParameterByName(param,dat[hI]) ###Attempt set data header/param name, dat[i] corresponding data at index
outSub.append("Success!(TXT)") ###If it succeedes report it
outSub.append(param) ###ADD PARAMS TO Output list
outSub.append(dat[hI]) ###ADD TABS + Data to output list
except:
outSub.append (" ERROR!:" + param)
outMain.append(outSub) ##Append Parameters success/fail
out.append(outMain)
out.insert(0,[["****Tab must be 'Sheet1'***************\n****'Mark' in row 1 must be defined****"]])
OUT=out
