Set parameter Value of a window family
Hi all,
I am trying to set the ’ Width ’ parameter of my Window Family to 800mm.( it is now 400mm ).
However the Set.ParameterByName node gives me the following error:
’ The parameters storage type is not a string ’ .
What does this error mean?
Thanks in advance!
Daan!
set width of window family|690x297
A String is a text, this parameter will only take numeric values.
use a code block and type 800 in it, that will give you the number 800, 200+600 in the code block will also give you 800, “200”+“600” in the code block will give you 200600 (text)
05-01-2018
Marcel
