Hi all,
I am trying to set Wall Top Constraint to Level and at the same time changing Top Offset to the Value from Unconnected Height.
The problem happened to be that the Top Offset is Read-Only until Top Constraint is changed to Level, but i can’t order the sequence of operations.
To sum it up, I need to change these to parameters at the “same time” without clicking Apply button.
Screnshoots attached.
Thank you in advance!
