Set Material of Category to Null
I try to set the material of a Revit Category to Null / Empty. Used the “Set SubCategory Properties” from GeniusLoci, what works well for assigning materials. But how to “deassign”? Inside Revit I can use the Button in the lower left. But how to do this with Dynamo???
THX
Have u tried with blank? ("")
Yes, I did. But that doesn’t work. Seems to a problem with the type.
Have you tried feeding it a null?
Yes - but didn’t work.
Hello @norbert_graeser …how about this ?
PS…the way i have done it in the image above, has this issue it delete the material from the library…
I havent find out yet, how to just empty the subcategori material, set to no material
Maybe this has some clue
Ah! It’s an element ID. The old -1 trick if I am not mistaken. Not sure how to produce that without Dynamo so editing the Python Konrad posted in that topic is the likely best path forward.
set Material to null (None) works perfectly (no need parameter)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
toList = lambda x : x if hasattr(x, '__iter__') else [x]
cats = toList(UnwrapElement(IN[0]))
for cat in cats:
	cat.Material = None
OUT = cats
from Revit API doc
You can also use
Mat = ElementId.InvalidElemtId
https://www.revitapidocs.com/2015/08ae8886-6ab3-3ef5-d2e0-0da2ffa7bd2c.htm
Thank you for your help!
"cat.Material = None" is what do the job in a perfect way.
