@SeanP Thanks. So Invisible is a GraphicStyle?! Looks like the Archilab node is using a different method instead of the FilteredElementCollector, hence why it is different.
With the invisible graphic style, I then needed to set the filled region perimeter. Filled regions don’t have a Line Style parameter so needed to use a different method. The Plissken package had this python code which works:
##Written By Thed Hogan
# Import RevitAPI
clr.AddReference("RevitAPI")
clr.AddReference('System')
from System import *
#The inputs to this node will be stored as a list in the IN variables.
app = DocumentManager.Instance.CurrentUIApplication.Application
#These are my inputs for the Node
filledRegion = IN[0]
toggle = IN[1]
gStyle = IN[2]
#Declared Variables
output = list()
startPoint = list()
endPoint = list()
existingLines = list()
profiles = list()
filledRegionCount = 0
collector = FilteredElementCollector(doc).WherePasses(ElementOwnerViewFilter(doc.ActiveView.Id)).OfClass(CurveElement)
for element in filledRegion:
filledRegionCount = filledRegionCount + 1
notProfile = True
idSub = 1
while notProfile:
if doc.GetElement(Autodesk.Revit.DB.ElementId(element.Id - idSub)).ToString() == "Autodesk.Revit.DB.Sketch":
profiles.append(doc.GetElement(Autodesk.Revit.DB.ElementId(element.Id - idSub)))
notProfile = False
idSub = idSub + 1
if idSub > 1000:
notProfile = False
#Collect existing <sketch> lines in the view, the toggle can reset the collection
if toggle == True:
for detailLine in collector:
if detailLine.get_Parameter(BuiltInParameter.ELEM_CATEGORY_PARAM).AsValueString() == "<Sketch>":
startPoint.append(detailLine.GeometryCurve.GetEndPoint(0).ToString())
endPoint.append(detailLine.GeometryCurve.GetEndPoint(1).ToString())
existingLines.append(detailLine)
#Check each filled region
for i in range(0, filledRegionCount):
#Set currentRegion:
currentRegion = profiles[i].Profile.get_Item(0)
changeRegion = False
#Find the Curves of Each Filled Region, using start and end points of existing lines in the <sketch> Category of the current view
#Compare the lines current linestyle to the given linestyle and determine if a change needs to happen
for curve in currentRegion:
if curve.GetEndPoint(0).ToString() in startPoint and curve.GetEndPoint(1).ToString() == endPoint[startPoint.index(curve.GetEndPoint(0).ToString())]:
#The Method .get_Parameter() was depricated after Revit 2015
try:
if gStyle[0].Name != existingLines[startPoint.index(curve.GetEndPoint(0).ToString())].get_Parameter('Subcategory').AsValueString():
changeRegion = True
#If the above fails, it means this is is being run in Revit 2016 or later, so we will use .LookupParameter() instead, the try/except allows us to avoid having to perform a Revit version check for a relatively minor change
except:
if gStyle[0].Name.ToString() != existingLines[startPoint.index(curve.GetEndPoint(0).ToString())].LookupParameter('Subcategory').AsValueString():
changeRegion = True
#If one or more Lines in the border are not the same as the given linestyle, begin a transaction to change that filled region
#This transaction must be nested inside of an if statement, to prevent it from running indefinitely and crashing the file while Dynamo is set to Automatic
if changeRegion == True:
UnwrapElement(filledRegion[i]).SetLineStyleId(ElementId(gStyle[0].Id))
#Send back the list of Filled Regions
output.append(filledRegion[i])
#Assign your output to the OUT variable.
OUT = output
