Hi
I want to ask you if there is a way to set the label text style. In particular, it is a band label
Thank you
Hi
Thank you
Hey,
The Camber package has nodes for dealing with a number of styles, unfortunately it does not currently cover Band styles.
Band styles are exposed by the API and specifically the Text Style you requested, so you maybe able to write a Python script to access it.
Autodesk Civil 3D Help | TextStyle Property | Autodesk
Ok thank you
I don’t understand what I have to give in input to the text style api function
It can be a good update for Camber Package.
A section dedicated to the bands. For example: put profile 1 and 2, and also the Data Source for the bands.
