Hello everyone , I am trying to set grid leader from linked models grids. I am facing some error with it in live project.
is there any way , that i can do it with dynamo nodes because i am not good at python.
You have to share your code … … to see how “bad” you are ! ![]()
#paste your bad code here!
let`s see your inputs too, maybe the mistake is in the input!
KR
Andreas
@Draxl_Andreas
Ha ha ha . I am very bad in python
Actually the script is working properly in normal projects but gets error in live project
here is the code :
Grid design.txt (3.5 KB)
thanks in advance .
kapil
#paste it via </>
import time
from Autodesk.DesignScript import *
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
from RevitServices.Transactions import *
from Revit import GeometryConversion
clr.ImportExtensions(Revit.GeometryReferences)
uiapp=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
view = doc.ActiveView
linkGrid = UnwrapElement(IN[0])
currGrid = UnwrapElement(IN[1])
linkView = UnwrapElement(IN[2])
resGrids = []
gName = []
gExtents = []
gExtents1 = []
TransactionManager.Instance.ForceCloseTransaction()
with Transaction(doc,"Add Leader to grids") as t:
#t = Transaction(doc,"Add Leader to grids")
t.Start()
lb=[]
lb1 = []
for i in range(len(linkGrid)):
leaderBase = linkGrid[i].GetLeader(DatumEnds.End1,linkView)
lb.append(leaderBase)
if leaderBase != None:
gExtents.append(leaderBase)
currGrid[i].AddLeader(DatumEnds.End1,view)
resGrids.append(currGrid[i])
leaderBase = linkGrid[i].GetLeader(DatumEnds.End0,linkView)
lb1.append(leaderBase)
currGrid[i].AddLeader(DatumEnds.End0,view)
#t.Commit()
t.Commit()
time.sleep(2)
#TransactionManager.Instance.ForceCloseTransaction()
#TransactionManager.Instance.EnsureInTransaction(doc)
with Transaction(doc,"Set Leader to grids") as t1:
t1.Start()
leader = currGrid[i].GetLeader(DatumEnds.End1,view)
anchor = leader.Anchor
end = leader.End
elbow = leader.Elbow
distY = (leaderBase.Elbow.Y - leaderBase.End.Y)
distElbowX = (leaderBase.Elbow.X - leaderBase.End.X)
distEndX = (leaderBase.End.X - leader.End.X)
newEnd = (Geometry.Point.ByCoordinates(leaderBase.End.X + distEndX,leader.End.Y,leader.End.Z)).ToXyz()
newElbow = (Geometry.Point.ByCoordinates(leader.End.X + distEndX + distElbowX, leader.End.Y + distY, leader.Elbow.Z)).ToXyz()
leader.Elbow = newElbow
leader.End = newEnd
currGrid[i].SetLeader(DatumEnds.End1,view,leader)
continue
leader = currGrid[i].GetLeader(DatumEnds.End0,view)
end = leader.End
leader.End = newEnd
currGrid[i].SetLeader(DatumEnds.End0,view,leader)
continue
t1.Commit()
#TransactionManager.Instance.TransactionTaskDone()
OUT="success"
Hey @Draxl_Andreas
I am new here, i did not know that.
is this code is working now ?
