Copy Grids From Linked Model
HI Guys,
I’m trying to copy the grids from a linked model (and rename them to match the name in the linked model ) using the following:
Curve Property
http://www.revitapidocs.com/2016/0fce3154-595f-62f5-65d7-e5065c1234a0.htm
Create Method (Document, Line)
http://www.revitapidocs.com/2016/462cb588-9811-e464-0fe9-13226a2fc8f7.htm
    # Import RevitAPI
    clr.AddReference('RevitAPI')
    from Revit.Elements import *
    collector = Autodesk.Revit.DB.FilteredElementCollector(doc)
    RevitLink = collector.OfClass(Autodesk.Revit.DB.RevitLinkInstance)
    RLink=list(RevitLink)[0]
    Grids = UnwrapElement(IN[0])
    LinkDoc =RLink.GetLinkDocument()
    filter = FilteredElementCollector(LinkDoc).OfCategoryId(Grids.Id).WhereElementIsNotElementType()
    LinkedGrids = [i.ToDSType(True) for i in filter]
    ToCurves,LinkedGridsName,ToGrid=[],[],[]
    #Get Curves from linked Grids
    for i in LinkedGrids:
        ToCurves.append(i.Curve)
    #Get Name of linked Grids
        LinkedGridsName.append(i.Name)
    for i in ToCurves:
        Grid.Create(doc,i);
    for i,j in zip(ToGrid,LinkedGridsName):
        i.Name=j
    OUT = ToCurves
I get the following error when I try creating the grids:
and the following error when I try renaming them (bypassing the first error using DS to create the grids:
for i in ToCurves:
    ToGrid.append(Grid.ByLine(i))
Also the items in Tocurve are the following type:
is this correct? Or I’m still using DS to get the curves?
Apologies if this is too long.
Please help me out, I’m stuck!:disappointed:
Why wouldn’t you just use the Copy/Monitor tool in Revit?
It’s something related to Dynamo. I tried with a macro and a PythonShell script and it works.
I just want to copy the grids in python
What do you mean? Dynamo can’t do it? Why?
Well, I really don’t know. I tried with a single grid but i got the same error: ‘type’ object has no attribute ‘Create’
Macro and Revit PythonShell script:
thanks @Organon
I posted the issue on github:
I got the following answer:
mjkkirschner commented 2 hours ago
you’ve imported both the revitapi and our wrappers which include a grid type:https://github.com/DynamoDS/DynamoRevit/blob/7270187e8688fbd8ec538b4617810dccdb9a695f/src/Libraries/RevitNodes/Elements/Grid.cs#L16
you need to be specific about what type you are referring to. You are probably referring to ours which does not have a Create method. Use the full module name.
To create the grid I changed to:
for i in ToCurves:
      Autodesk.Revit.DB.Grid.Create(doc,i);
but still Dynamo is not happy and gives me this error:
Ideas :grin:?
Why don’t you extract only the geometry of the linked grids and use the native grid creation nodes?
Because this is part of a bigger workflow, I’d like to use Python only
Any ideas why it doesn’t accept the Lines the way I extracted them?
Yes, because you’re mixing your namespaces. There’s a Dynamo Line class and a Revit.DB.Line class. You’ll need to convert your dynamo lines to revit lines first.
What’s the problem of integrating the native nodes in a bigger workflow?
okay thanks. I’ll try to convert…
Or could I get the revit lines directly> Without going through Dynamo lines?
Also I’d like to learn just to use python…It’s a good learning process.
Yes, you can totally do that. The problem arises in this line
With the ToDSType method you’re converting the grid from a revit grid to a dynamo grid and later when you call the Grid.Curve property, the result is the same as using the built-in “Grid.Curve” node and you get a dynamo line. If you remove the the whole line or at least the “.ToDSType(True)”, the grid creation should go through.
This code works:
# Import RevitAPI
RLink=IN[0]
grids=FilteredElementCollector(LinkDoc).WherePasses(ElementCategoryFilter(BuiltInCategory.OST_Grids)).WhereElementIsNotElementType().ToElements()
for i in list:
for i in list:
for i in ToCurves:
	a = Autodesk.Revit.DB.Grid.Create(doc,i)
	ToGrid.append(a)
#for i,j in zip(ToGrid,LinkedGridsName):
#	i.Name=j
OUT = ToGrid
Thank you for pointing to the right direction :slight_smile:
Thank you :slight_smile:
Any way that this full workspace and any custom nodes could be uploaded? Grid lines are currently a pain in the &%# when we get new projects. The ability to have dynamo create gridlines and rename them accordingly would be hugeeee!
Any help would be much appreciated as I dont even know where to start when it comes to custom nodes in python :frowning:
Hi @RAllan
I am not on a pc to check the python code on top but as i can see its a straight forward copy and paste to a python script node and follow. They might eventually post the completed dyn who knows…:blush::thinking::wink:
Hi Rob,
It looks like we are exploring the same possibilities :wink:
A few months ago i created the below (beta)workflow, witch copies grids and levels from a linked model.
Due to lack of time, i haven’t finished it (couldn’t get the part of setting the right Grid types to work).
Copy Grids and Levels from Linked Model_beta.dyn (195.6 KB)
Maybe it can be of help for you.
Kind regards,
Mark
Will try and have a look at the above and see what I can make of it. something tells me im in way over my head though :stuck_out_tongue:
Thanks @MJB-online, exactly what I wanted
