I want to set the Detail Number of a view and if it is already in use i don´t want to get this error:
I want the code to don´t set the number if it is not possible, but i dont want this error to show up.
Is this possible somehow? My attempt with Try/Except did not work, i get the error again.
for viewport in viewports:
detailnumber = viewport.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER)
try:
NewNumber = detailnumber.Set("5")
OUT = outlist.append(NewNumber)
except:
message = "fail"
OUT = outlist.append(message)
If it is not possible i have to check the numbers before and build some logic for that. Just avoiding this error would be easier.
I don’t think ‘try, except increase and try again’ is the right process here.
Get all the details, find the last one, add one to that, and start the sequence there. A single quantifiable action vs many potentially failed actions.
I had the problem that a failed attempt for setting the detail number will kill the whole dynamo script, even undoing tasks that already worked successfull.
Yes, I will check a list of the current numbers before setting new ones. Avoiding the error sould be an additional safety net, but if it’s not possible i have to live without it.
I now just use an if x not in y statement to make sure the detail numbers don´t already exist.
Final_DetailNumbers = []
for i in numbers:
if str(i) not in Filtered_DetailNumbers:
Final_DetailNumbers.append(str(i))
Full code:
clr.AddReference("RevitAPI")
app = uiapp.Application
if isinstance(IN[0],list):
New_Views = UnwrapElement(IN[0])
New_Views = [UnwrapElement(IN[0])]
New_View_DetailNumbers = []
for New_View in New_Views:
ID = New_View.SheetId
New_View_DetailNumber = New_View.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER).AsString()
try:
integer=int(New_View_DetailNumber)
New_View_DetailNumbers.append(integer)
except:
pass
Sheet = doc.GetElement(ID)
viewIDs = Sheet.GetAllPlacedViews()
all_viewports = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Viewports).WhereElementIsNotElementType().ToElements()
Current_DetailNumbers = []
for viewport in all_viewports:
viewportId = viewport.ViewId
for viewID in viewIDs:
if viewID == viewportId:
Current_DetailNumber = viewport.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER).AsString()
try:
integer=int(Current_DetailNumber)
Current_DetailNumbers.append(integer)
except:
pass
Filtered_DetailNumbers = []
for Current_DetailNumber in Current_DetailNumbers:
if Current_DetailNumber not in New_View_DetailNumbers:
Filtered_DetailNumbers.append(Current_DetailNumber)
if Filtered_DetailNumbers:
max=int(max(Filtered_DetailNumbers))
max=0
n = 100
numbers = []
for i in range(max+1, n+1):
numbers.append(i)
for i in numbers:
for V, f in zip(New_Views, Final_DetailNumbers):
V.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER).Set(f)
OUT = New_View_DetailNumbers,Current_DetailNumbers, Filtered_DetailNumbers, Final_DetailNumbers, New_Views
