Selection Region as Polygon
I don’t believe Revit API naturally does this. My guess is they use a while loop and yield a bunch of picked points to form a polygon, extrude it, then solid intersect it with element bounding boxes or something along those lines.
You can prompt point selection using this class/method:
Just tried it out and it works, put this in a Python node with no inputs and one output, then run and pick your points and hit escape to finish and send them on. These can them form a solid polygon, and you could also convex hull them if you’re worried about user point order. I’m guessing if you use C# you can also render the points/edges as you go versus Dynamo where you draw blindly. I guess you could make annotation lines temporarily using transactions at each step of the way?
# Boilerplate text
clr.AddReference("RevitAPI")
clr.AddReference("RevitAPIUI")
# Current doc/app/ui
app = uiapp.Application
# Inputs and variables
uisel  = uidoc.Selection
msg    = 'Pick points, then hit escape to continue.'
ptList = []
keepPicking = True
TaskDialog.Show("Pick polygon", msg)
while keepPicking:
	try:
		xyz = uisel.PickPoint(msg)
		ptList.append(xyz.ToPoint())
	except:
		keepPicking = False
OUT = ptList
