Hannes
1
Hi, i need to select height and width from the type parameters. These parameters are only visible if your select “Edit Type”.
I know how to select the parameters if they are in the Properties. But in this case…they aren’t:(
It is possible to select the height and width?How?
You need to access the element Type, not the element itself.
Hannes
3
Thx for your fast and simple help! The Rhythm node didn’t work for me, but the node from clockwork does.
Thx, and have a nice day:)
I’m trying to do the same thing, but not having luck with either package. Do you know if these are still compatible or what else I can do? Thanks!
Hi @jrthill
Which parameters you’re trying to extract? Could you please start new thread. This post is already solved.
