Select the topography created with building pad
Hi Everybody.
I’m trying to select the topography created with building pad for calculate cut and fill. any ideas?
In this moment the quantities are of the past process.
Thanks!
This is quite simple with a little bit of Python Code:
GetAssociatedTopo.DYN (4.9 KB)
clr.AddReference('System')
clr.AddReference("System.IO")
from System import *
from System.Reflection import *
from System.IO import *
#Use elemIds = List[ElementId](ids) for ICollection(ElementId)
#Import the Revit Services
app = uiapp.Application
#Import the Revit Nodes
#Import the Revit API
clr.AddReference("RevitAPI")
#Import math functions
import math
def tolist(obj1):
    if hasattr(obj1,"__iter__"):
        return obj1
        return [obj1]
#Define Input (IN)
buildingPads = tolist(UnwrapElement(IN[0]))
output = []
# Start Transaction
for pad in buildingPads:
    topoId = pad.AssociatedTopographySurfaceId
    topo = doc.GetElement(topoId)
    output.append(topo)
#End Transaction
#Define Output (OUT)
OUT = output
Thaks my friend, in theory is exctly what i need. But, for some reason, dynamo don’t recognize the quantities in this model
I solve it, with transaction.end node. Thanks my friend
