Select Objects in Drawing
Does anyone know of a way to select objects in a drawing, similar to how QSELECT works? I want to be able to select objects based on additional criteria that you can’t do with QSELECT, such as property set data.
By “select” I mean actually grabbing and highlighting objects in the drawing, just like if you click on them.
Hi @zachri.jensen
Is this what you’re trying to achieve?
Not quite - I’m looking for the process to work in the other direction. For example, I’d like to use ObjectByProperty to get objects that match certain criteria, and then highlight/select those objects in C3D.
Can you drop here dwg sample file which contains objects property?
I think you need to use Python to create a selection set.
@Kulkul see attached. I’d like to be able to select/highlight objects by phase, segment, or a combination.
Property Set.dwg (393.8 KB)
@zachri.jensen thanks for dropping i will look at it in the morning.
Hi @zachri.jensen
Yep, that’s it! Are you willing to share the Python snippet? Or explain some of the steps involved so that I can do it?
Here you go @zachri.jensen For Zachri Jensen.dyn (13.6 KB)
Please mark the post as solved.
You’re Welcome!
Done. Thanks @Kulkul!
There are nodes for this in Camber v2.0.0.
