I’ve read lots of post to this similar Topic, but nothing to ever solidly answer “when those objects are in Child Views” that the Clockwork’s node Element.OwnerView seems to miss.
A great example I’ve read more commonly is selecting Revision Clouds that are on Dependent Views (Partial Plans). So here’s a great case scenario. I’m trying to find a way of not going into each of those views separately to run the script to override graphics. Attached script is where I’m currently at where I’m testing different avenues.
My ultimate goal is to be able to create a visual Cue based on Instance Parameters, then be able to Reset those overrides the same way they were selected to begin with.
Any help in this example to get all “Elements” (either if 2D or 3D) that are on Dependent Views when selecting by a given parameter to filter them out is much appreciated. Getting them when in Independent Views is the easy part.
Override RevCloud Color_for Dependent Views v2.dyn (57.3 KB)
