Script for making a floor using polyline CAD
Question please
How to create a script that can create a floor at the height of the street using an AutoCAD 3D file
Note **(Boundary roads are closed with polyline from the CAD file)
@Hussinghannam1 youcan access to cad com Api to get the boundaries from cad to revit then use it to creat the slab. Also you can access to the surface if you have. You can use BriMohareb_xxxx pak. To access to autocad or c3d objects from Revit
