Hi fellow Revit Users,
I tried to add a simple Rvt SaveAs Function after the IFC Export Script but I encountered an InternalException that doesnt make much sense to me, because it saved the Revit File and it’s open in the background. I’m confused.
After searching since yesterday, not even the “TransactionManager.Instance.ForceCloseTransaction()” function helped me.
The Error is:
Python Script - RVT SAVE AS,1,“InternalException : A managed exception was thrown by Revit or by one of its external applications. bei Autodesk.Revit.DB.Document.SaveAs(String filepath, SaveAsOptions options) [’ File “””“, line 29, in \n’]”,null
The code for the Revit SaveAs Script:
import os
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import Transaction, SaveAsOptions
save_path = IN[0]
file_name = IN[1]
lets_go = IN[2]
##lets_go is a boolean value that turns true when the export of the IFC Export is done
sOption = SaveAsOptions()
sOption.OverwriteExistingFile = True
save_path_full = save_path + "\\"
file_name_rvt = file_name + ".rvt"
if lets_go:
doc.SaveAs(save_path_full+file_name_rvt, sOption) ##line 29 btw
OUT = f"Modell im Datenausgang gespeichert"
