Hi sovitek,
When I run the layer 32mm to 32mm pipe, it works. But when I run again the others layer 40mm to 40m pipe, the 32mm pipe disappeared. How to solve it? Thanks.
Hi @pe_simon sounds like element binding…try run it from player for avoid that
how to run it from player?
And can I run it at same times? Thanks.
For example, 32mm, 40mm, 50mm layer to 32…50 pipe…
yes should be possible its about list level and lacing i guess
Check the Element Binding post and associated content in it for more info.
yeps and still the best explanation on that on the forum…so great ![]()
