Hey guys I have just started to use RPS and iam facing the issue at the end of the script it says
SetElementIds() takes exactly 2 arguments (1 given)
but on the API docs it expects only one
here is my script
#Import Autodesk stuffs
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Selection import *
# Import iron python packages
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
app = __revit__.Application
doc = __revit__.ActiveUIDocument.Document
#get All category in the Document
AllCategory = doc.Settings.Categories
ModelCategory = []
ModelCategoryName=[]
for x in AllCategory:
if x.CategoryType == CategoryType.Model:
ModelCategory.append(x)
ModelCategoryName.append(x.Name)
CategoryDictionary = dict(zip(ModelCategoryName,ModelCategory))
#Create Forms to record User Inputs
from pyrevit import forms
Selection=forms.CommandSwitchWindow.show(ModelCategoryName,message='Pick type category')
index=ModelCategoryName.index(Selection)
SelectedCategory=ModelCategory[index].Id
# collect element of selected Category
Collector = FilteredElementCollector(doc)
items= FilteredElementCollector.OfCategoryId(Collector,SelectedCategory).WhereElementIsNotElementType().ToElements()
ParameterName = forms.ask_for_string("Enter the parameter Name")
OperatorList=[" Equals to","Less than","Greater than",]
Operator = forms.CommandSwitchWindow.show(OperatorList,message='Choose Operator to compare')
CompareWith = forms.ask_for_string("Enter the a value to compare")
out=[]
if Operator == "Equals to":
for a in items:
a.LookupParameter(ParameterName).AsDouble() == CompareWith
if True:
out.append(a.Id)
elif Operator == "Less than":
for a in items:
a.LookupParameter(ParameterName).AsDouble() < CompareWith
if True:
out.append(a.Id)
elif Operator == "Greater than":
for a in items:
a.LookupParameter(ParameterName).AsDouble() > CompareWith
if True:
out.append(a.Id)
from Autodesk.Revit.UI.Selection import Selection
from System.Collections.Generic import List as CL
finalout=[]
for a in out:
finalout.append(a.Id)
Sel = CL[ElementId](finalout)
Toselect = Selection.SetElementIds(doc,Sel)
Can Someone help me figure this out
Edit : This is the error That is returned by RPS
