I know that this is an old post but I’m interested it trying to get the for loop to work. I’m confused as to where it needs to go to get lists to work. I’ve tried this with null results.
import math
#Preparing input from dynamo to revit
element = UnwrapElement(IN[0])
angle = IN[1]*math.pi/180
#calculte rotation axis:
#for angle in angle:
# baseVector = element.BaseDirection
# upVector = element.UpDirection
# normalVector = baseVector.CrossProduct(upVector)
# axis = Line.CreateUnbound(element.Coord, normalVector)
#Do some action in a Transaction
for element,angle in (element,angle):
ElementTransformUtils.RotateElement(doc, element.Id, axis, angle)
OUT = 0
I’ve also tried this: Still nothing, but I think I’m closer. From this thread using Kulkul’s example it seems like a need to used the for loop to create a list for the rotate command to use. In this case I would need three: element, axis, and angle.
https://forum.dynamobim.com/t/move-text-notes-by-cordinates/17113/13
import math
angle = IN[1]
#element list
ids = list()
for element in element:
ids.append(item.Id)
elementlist = List[ElementId](ids)
#angle list
anglelist = list()
for angle in angle:
anglelist.append(angle*math.pi/180)
axis = list()
for axis in angle:
axis.append(Line.CreateUnbound(element.Coord, normalVector))
ElementTransformUtils.RotateElement(doc, elementlist, axis, anglelist)
OUT = 0
Here is what the custom node looks like:
