Rotating curtain wall panels
Hi everyone, thank you for your help. I am new here, any idea welcome!
I would like to create a curtain wall consists of gradually rotating curtain wall panels. Would you mind giving me some directions ?
Thanks in advance !
Ku2322i
Hello Kui Xue,
I have come up with the solution which is no so user-friendly, but it achieves your expected results.
I will provide the better solution soon.
For now you can use this solution.
Download my Package from Package Manager. (RotateAdaptiveComponentDuringPlacement)
Sample Files are here…rotating curtain wall panels revit file 4PointADC you have to load this family to your project.
Thanks,
Ritesh
RotateADC
Hi Ritesh,
Thank you very much!
I 'll try it now.
Kui
Hi Ritesh,
Thank you for your help. However I was not able to download the package you mentioned.
Ā
When I was posting this question, I was thinking just use a generic curtain wall family . As shown in the first image, I set up an instance parameter ā€œAngleā€ to drive the angle of the curtain wall panel. And then load this family into the project file.
So in Dynamo, if we can assign right value to "Angle " parameter , then we can get what I expect as shown in the third image (using Element.SetParameterByName) . I don’t know how to assign a list of values according to the location of different curtain wall panels or baguettes.
Will this approach work? Thank you so much! Kui
Project curtain wall
@Kui Xue - See if this works.
Project File with a Curtain Panel Family: CW-RotatingPanels.rvt
Dynamo Definition: RotateCurtainPanels.dyn
Ā
20150715-2
@<span class=ā€œauthor-linkā€>Vikram Subbaiah</span>
Thank you very much Vikram!
