i tried GeniusLoci RotateFitting node, seems working only for pipes, anyone have luck rotating duct fitting? mine is just simple Round Takeoff duct fitting
hi, that one doesnt work if you have taps, then you need rotate about the vector and point and connect again, but possible and @Andriy have give some examples how it could be done with some nodes…one possible way
thanks sovitek, right, most existing nodes are quite limited, need more universal one
can you tell us where rotate by vector and point are quite limited ?
ElementTransformUtils ??
ElementTransformUtils should work for all cases, i’ll try to put together customized Python node w/ only fitting and angle as inputs, i believe fitting should provide necessary info. about rotation axis and center of rotation
allright as here ?
