Rotate assembly origin issue
My question is not new, here is link to discussion and solution looks good. But I have the issue like on picture below. The problem that I don’t know how to fix that, according apidocs this method still available.
import math
clr.AddReference("ProtoGeometry")
doc =  DocumentManager.Instance.CurrentDBDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
clr.AddReference("RevitAPI")
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
run = tolist(IN[0])[0]
elems = tolist(UnwrapElement(IN[1]))
axis = tolist(IN[2])
rot = tolist(IN[3])
outList = []
if run:
	for e, a, r in zip(elems, axis, rot):
		trans = e.GetTransform()
		transRot = trans.CreateRotationAtPoint(a.ToXyz(),math.radians(r), trans.Origin)
		try:
			e.SetTransform(transRot)
			outList.append(e)
		except Exception:
			outList.append(e.message)
	OUT = outList
	OUT = "Please set Run to True"
Try changing trans to Transform
transRot = Transform.CreateRotationAtPoint(a.ToXyz(),math.radians(r), trans.Origin)
I believe in this line you want to create a new transform (called “transRot”) to set the transform properties of the element to and not trying to change the attribute of the element’s existing transform. Then you are applying the new transform properties to the element in the e.SetTransform(transRot) line. I am no means proficient when it comes to coding, so I may not be stating this correctly.
Thank you, @staylor. I’ve saved a ton of time for me!
