I tried to write a script that aligns the axes of assembly origin point relative to the selected plane and rotates it 180 degrees around Z axis. I encountered this error and can’t understand what I’m doing wrong?
Here is an original code
This topic can’t solve my problem
import math
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript import Geometry as Geom
app = DocumentManager.Instance.CurrentUIApplication.Application
clr.AddReference("RevitAPI")
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
run = tolist(IN[0])[0]
assem = tolist(UnwrapElement(IN[1]))
plane = tolist(UnwrapElement(IN[2]))[0]
point = tolist(IN[3])[0]
normal = tolist(IN[4])[0]
outList = [ ]
if run:
a, p,pt,n = assem, plane, point, normal
ax = p.XAxis
ay = p.YAxis
trans = a.GetTransform()
trans.Origin = pt.ToXyz()
trans.BasisX = n.ToXyz()
trans.BasisY = ay.ToXyz()
trans_rot = trans.CreateRotationAtPoint(trans.BasisZ, math.radians(180), trans.Origin)
try:
a.SetTransform(trans_rot)
TransactionManager.Instance.ForceCloseTransaction()
outList.append(a)
except Exception as ex:
outList.append(ex)
OUT = outList
OUT = "Please set Run to True"
