Good morning everyone,
I have an issue in Dynamo when using rooms from linked model.
I was working based on: Elements in Linked Rooms using Dynamo! - YouTube
as a part of my script for filling in data.
Unfortunately when I use it my rooms are being shifted.
Architectural model in Revit is OK, everything is in right place, but this “import” of rooms is shifted. Can you explain me why? or what should I check? Is it because location of internal origin?
Any advices will be very helpful for me. Thank you in advance.
@13_IKo , hi
Did you place your model correctly ? origin to origin
KR
Andreas
SeanP
May 18, 2022, 11:40am
4
You may need to get the Transform of the linked model.
Hey all, I have a problem with linked files in a host Revit document. Basically, I create a new document, link my clients document to mine and then do my stuff in my document only, not touching the original documents. Then I send my work to the...
When I have Copied spaces /rooms that’s how I have done it.
OK, thank you I will check it
13_IKo
June 3, 2022, 10:19am
6
Ok, so the problem is that in one model was moved and origin is in different place.
Thank you for pointing that out.
I am wondering if there is and node to change coordinate system? To base for example on base point instead of internal origin?
