Hello forum members.
I am looking for a way to get the Room Bounding References per Room.
Room.Boundaries from CLockwork gives me the Room bounding elements, but is there a way to get only the Room bounding faces?
Would it work getting the rooms’ geometry (solid) and then the vertical faces?
True. That will give me the room faces.
But i would like to get the wall inner face (which represents the room boundary) or the face which is the closest to the room center point
There‘s a fairly new node in Clockwork called Room.Finishes - I believe it should get you what you want.
