Hello everybodies,
I would like to use this script but Dynamo is telling me that some of nodes are unresolved!
Fact is, i don’t understand cause i have this kind of nodes includ in my latest version of Rhynamo.
If you have a solution to resolve this kind of issue!
Thank you very much!
Unresolved means that the package is not installed… if you restart your pc most will probably go away… if not replace the yellow nodes in the graph with the corresponding nodes from the package…
Hello again,
So I replace the yello nodes which were unresolved by the nodes of the rhynamo package.
But it still doesn’t work.
Do you have some other tips please?
Thank you very much! RhynamoExample.dyn (49.2 KB)
For exemple the first Yello node is telling me this : "Avertissement:RhinoObject.Get_RhinoLayerNames l’opération a échoué.
Impossible de charger le type ‘Rhino.DocObjects.ModelComponent’ à partir de l’assembly ‘Rhino3dmIO, Version=5.1.30000.14, Culture=neutral, PublicKeyToken=null’.
So I checked with a demo on Proving Ground and actually the process was done with rhino 5.0 and I use the same!
The question is still unsolved yet!
So If you have or anybody else has tips about that Topic, feel free to share with me!
Thank you very much
