Rheotomic Surface, how?
i got hypnotized by these forms? is there anything to built up this in dynamo ? or placing families based on that :slight_smile:
KR
Andreas
Hi, you looked on the site (there is his address on his file) of Mr. Vikram
Mr. Marcel must have leads too I think, he seems a fan of geometric objects
cordially
christian.stan
@christian.stan ,
so i “awake” them to this topic :wink: @Vikram_Subbaiah @Marcel_Rijsmus
Let me sleep on it :smile:
No ,seriously i’ve moved onwards since.
Maybe @Vikram_Subbaiah can be of assistance
Here is a surface I don’t know if it comes within the prerogatives, you can add a little movement to the cylinder
23 janvier funny Draxl.dyn (29.1 KB)
cordially
christian.stan
Not Rheotomic, but this thread has similar things :smiley:
Hi @Draxl_Andreas you could have a look at this grasshopper script if you have access to rhino:
If you have, but haven’t worked with grasshoppoer yet: It’s quite similar to dynamo and you should have no problem in analysing how the script works.
Here is a demo video of the author using his script:
@christian.stan @solamour @Marcel_Rijsmus @leonard.moelders ,
it is fake but funny … i found something to the Dyole function
thats exposed to the grasshopper graph as pythoncode…
#Seghier Mohamed Abdelaziz - 2021
import Rhino.Geometry as rg
import ghpythonlib.components as ghc
import math
pow = math.pow
sin = math.sin
cos = math.cos
pi = math.pi
sqrt = math.sqrt
q = p*n
def prop(z,t,p,q):
    w = pow(z,p/q)
    s = (p*t+2*pi)/q
    v = [w,s]
    return v
def _d(z,t,p,q):
    w = pow(z,p/q)
    s = (p*t+2*pi)/q
    v = pow(z*cos(t)-w*cos(s),2)+pow(z*sin(t)-w*sin(s),2)
    return v
def ddz_d(z,t,p,q):
    w = pow(z,p/q)
    s = (p*t+2*pi)/q
    ddz_w = (p/q)*pow(z,(p-q)/q)
    v = 2*(w*cos(s) - z*cos(t))*(ddz_w*cos(s) - cos(t))+ 2*(w*sin(s) - z*sin(t))*(ddz_w*sin(s) - sin(t))
    return v
def ddt_d(z,t, p,q):
    w = pow(z, p/q)
    s = (p*t + 2*pi)/q
    dds_t = (p/q)
    v = 2*( z*cos(t) - w*cos(s) )*( -z*sin(t) + w*sin(s)*dds_t )+ 2*( z*sin(t) - w*sin(s) )*( z*cos(t) - w*cos(s)*dds_t )
    return v
def _s(z,t, p,q):
    v = pow(z + pow(z, p/q), 2)
    return v
def ddz_s(z,t, p,q):
    w = pow(z, p/q)
    ddz_w = (p/q)*pow(z, (p-q)/q)
    v = 2*(w+z)*(ddz_w+1)
    return v
def _r(z,t, p,q):
    v = _d(z,t,p,q) / _s(z,t,p,q)
    return v
def ddz_r(z,t, p,q):
    v = (ddz_d(z,t,p,q) * _s(z,t,p,q) - _d(z,t,p,q) * ddz_s(z,t,p,q)) / pow( _s(z,t,p,q), 2 )
    return v
def ddt_r(z,t, p,q):
    v = (ddt_d(z,t,p,q) * _s(z,t,p,q)) / pow( _s(z,t,p,q), 2 )
    return v
def _f(z, t):
            return _r(z,t,0,1) - _r(z,t,p,q)
def ddz_f(z, t):
            return ddz_r(z,t,0,1) - ddz_r(z,t,p,q)
def ddt_f(z, t):
            return ddt_r(z,t,0,1) - ddt_r(z,t,p,q)
def _g(z, t):
            return _r(z,t,0,1) - _r(pow(z, p/q), (p*t + 2*pi)/q, 0 ,1)
def ddz_g(z, t):
            return ddz_r(z,t,0,1) - ddz_r(pow(z, p/q), (p*t + 2*pi)/q, 0,1) * (p/q)*pow(z, (p-q)/q)
def ddt_g(z, t):
            return ddt_r(z,t,0,1) - ddt_r(pow(z, p/q), (p*t + 2*pi)/q, 0,1) * (p/q)
class doyle:
    def find_root(z, t):
       for i in range(100):
            v_f = _f(z, t)
            v_g = _g(z, t)
            z= z; t= t; r= sqrt(_r(z,t,0,1))
            a = ddz_f(z,t)
            b = ddt_f(z,t)
            c = ddz_g(z,t)
            d = ddt_g(z,t)
            det = a*d-b*c
            z -= (d*v_f - b*v_g)/det
            t -= (a*v_g - c*v_f)/det
       return z,t,r
    root = find_root(2,0)
    z = root[0]
    t = root[1]
    r = root[2]
    a = [z * cos(t), z * sin(t) ]
    _z = pow(z, p/q)
    _t = (p*t+2*pi)/q
    _r = 0.0
    b = [_z * cos(_t), _z * sin(_t) ]
a= doyle.a; b= doyle.b; r=doyle.r; mod_a = z = doyle.z; t= doyle.t
def cmul(w,z):
    v = [w[0]*z[0] - w[1]*z[1],w[0]*z[1] + w[1]*z[0]]
    return v
def modulus(p):
    v = sqrt(p[0]*p[0] + p[1]*p[1])
    return v
def crecip(z):
    d = pow(z[0],2)+pow(z[1],2)
    v = [-z[1]/d, z[0]/d]
    return v
circles = []
def Spiral(r, start_point, delta, min_d, max_d):
    recip_delta = crecip(delta)
    q = cmul(start_point, recip_delta)
    mod_q = modulus(q)
    circle = rg.Circle(rg.Plane.WorldXY, rg.Point3d(q[0], q[1], 0), mod_q*r)
    circles.Add(circle)
    q = cmul(q, recip_delta)
    return circles
scale = pow(mod_a, -1)
min_d = scale
n = n-1
max_d = q*n
start = a
for i in range(max_d):
    start = cmul(start, b)
    Circles = Spiral(r, start, a, min_d, max_d)
def mobius(g,c,a,q,bool):
    G = ghc.trees.Kangaroo2Component.MbiusTransformation(g,c,a,q,bool)
    return G
G = ghc.trees.PolarArray(Circles,rg.Plane.WorldXY,p,2*pi)[0]
if T == True:
    G = ghc.trees.FlipMatrix(G)
    C = ghc.Circle(rg.Plane.WorldXY,pi*C)
    G = mobius(G,C,pi/2,Q,False)
    G = ghc.trees.Rotate(G,pi/2,rg.Plane.WorldZX)[0]
    G = mobius(G,C,-pi/2,0,False)
    R = ghc.trees.DeconstructArc(G)[1]
    P = ghc.trees.Evaluate('if(x>10,0,1)',R)
    G = ghc.trees.CullPattern(G,P)
Doyle_Spiral_V01.dyn (96.2 KB)
