Hello, Does anyoune know if is it possible to rewrite, DWG Export options during dynamo export process, if i have for example walls in same pattern field but in different type, and thickness, and i want it to have in different layers in autocad when process is completed ?
@marek1992 there are no bimorphNodes which handle customising DWG export settings. I assume you are already aware of Revit’s OOTB mapping table when exporting to DWG? Does this not meet your requirements without the intervention of Dynamo?
This doesnt meet my requierements, :/, i think only one possible solutions is to make a script which change the parameters of constructions before exporting, a then revers it back ,
