Hi all,
I need to delete schemas from the data base. But the Revit API is different regarding this from version 23.
I cant find an alternative method compatible with revit 24. I am using python, but c# or anything would be helpfull.
Thank you!!
Hi all,
Thank you!!
This method has been around since 2021, and didn’t change between 2023 and 2024 from what I can see. Are you seeing otherwise?
