I’m setting up some schemas in Revit… All of them have very similar code but for some reason I keep having issues with this one- in particular the second to last line that is trying to get the dictionary? Any idea why?
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.ExtensibleStorage import *
from Autodesk.Revit.UI.Selection import ObjectType
import System
import sys
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary, IDictionary
#Get the GUID
schemaId = System.Guid(IN[0]) #Guid
schemaName = IN[1] #String
#unwrap
myChosenDBobject = UnwrapElement(IN[2][0]) #Project base point
schema = ExtensibleStorage.Schema.Lookup(schemaId)
def add_schema_instance(schema, myChosenDBobject, pydict = {}):
# get Field from DataStorage
fieldDict = schema.GetField("Dict_Data")
# set schema and store some datas
schema_instance = Entity(schema)
# store Datas Element in Dictionary
stringMap = Dictionary[System.String, System.String](pydict)
schema_instance.Set[IDictionary[System.String, System.String]](fieldDict.FieldName, stringMap)
myChosenDBobject.SetEntity(schema_instance)
return myChosenDBobject
# Begin transaction
# Create the schema if it doesn't exist
if schema is None:
builder = ExtensibleStorage.SchemaBuilder(schemaId)
builder.SetReadAccessLevel(ExtensibleStorage.AccessLevel.Public)
builder.SetWriteAccessLevel(ExtensibleStorage.AccessLevel.Public)
builder.SetSchemaName(schemaName)
builder.SetDocumentation("This is the series information for the issue sheet")
# Create dictionary for series descriptions
Dict = builder.AddMapField("Dict_Data", System.String, System.String)
Dict.SetDocumentation("Dictionary for series descriptions")
schema = builder.Finish()
BuildInfo = "Schema created successfully."
BuildOutput = True
######## Add all current series descriptions
fields = {
"10": "Site, Existing, Demolition",
"18": "Other Substructure Elements",
"20": "General Arrangements",
"21": "External Walls",
"22": "Internal Walls",
"23": "Floors",
"31": "Windows / Exterior Doors",
"32": "Internal Doors",
"35": "Ceilings",
"40": "Finishes",
"68": "Security & Fire"
# Create the data dictionary
data_dict = {"00": "WholeBuilding (Glossaries,Specs etc)"}
# Store initial data
add_schema_instance(schema, myChosenDBobject, data_dict)
# Loop through the fields and add them
for key, value in fields.items():
data_dict[key] = value
BuildInfo = "Schema already exists."
BuildOutput = True
doc.Regenerate()
entity = myChosenDBobject.GetEntity(schema)
### I keep getting errors on this next line... Why?
dictionary = entity.Get[IDictionary[System.String, System.String]]("Dict_Data")
OUT = dictionary, BuildInfo
Edit:
So it already exists… But why is the try bit not working if it exists?
