Revit Line loads through Dynamo
Hi
I am trying to create hosted line loads for wall elements through Dynamo, but I have some difficulties. I have tried the method in this thread: “http://dynamobim.org/forums/topic/line-loads-creation-via-python/”, but I would like the line load to follow the analytical wall element - if possible.
I don’t know how to select the hosted line in Dynamo and thereby define a hosted line load.
Regards Anders
Hei Anders,
You have to use this metohod: http://www.revitapidocs.com/2017/2e299798-26c8-9e42-47de-d496151d1e3d.htm
C#:
public static LineLoad Create(
	Document aDoc,
	AnalyticalModelSurface host,
	int curveIndex,
	XYZ forceVector1,
	XYZ momentVector1,
	LineLoadType symbol
In python you can do something like this:
LineLoad.Create( aDoc,host, curveIndex, forceVector1, momentVector1, symbol)
The challenge here is to find the correct curveIndex. The surfaces boundary curves are stored in a certain order, and you need to find which index the curve you need has. You can use Dynamo for that, in this example I found the index of the line with the largest z-value in the midpoint of the lines.
with this script for finding the boundary curves:
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
curveloops = element.GetLoops(AnalyticalLoopType.External)
if len(curveloops) < 2:
	OUT = [curve.ToProtoType() for curve in curveloops[0]]
Hi Einar
Thank you for the help, this was exactly what I needed.
No problem! It would be nice if you share the end result when you make it work and mark it as resolved.
I got it to work!
Here is a simple example
Again thanks for the help!
You can find a similar topic here:
Complete newbie here. Any idea as to what I did wrong? Thank you very much!
File “”, line 29, in
TypeError: expected AnalyticalModelSurface, got AnalyticalModelStick
