Revit.Line intersects Revit.Plane and creates point?
Here is my result with Dynamo 3.1 (.Net8)
I attach the dyn for test
compute_line_intersection_forum_DYN3_v0.2.dyn (33.4 KB)
Unfortunately, Tuneup is not currently available on dynamo3.
:cry:
A little elf told me that this is something being reviewed already, but there is no eta at this time.
The dyn file is outdated a bit, could you upload last version, please?
need to open the file with Dynamo3 or more, if you open this dyn in Dynamo2.x the Ironpython3 node disappear (old dynamo bug)
@Vladimir ,
finally someone helped me in a forum, with this masterpiece.
import math
from pyrevit import revit,forms,script
clr.AddReference('RevitAPI')
from  Autodesk.Revit.UI import*
from  Autodesk.Revit.UI.Selection import*
doc = __revit__.ActiveUIDocument.Document
view = doc.ActiveView
uidoc = __revit__.ActiveUIDocument
app = __revit__.Application
DB = Autodesk.Revit.DB
output = script.get_output()
unit = doc.GetUnits()
selection = uidoc.Selection
class SelectionFilter(ISelectionFilter):
    def __init__(self, categories):
        self.categories = categories
    def AllowElement(self, element):
        if element.Category.Name in self.categories:
            return True
        return False
    def AllowReference(self, reference, point):
        return False
def ToLst(ele):
    if isinstance(ele,list):
        return ele
        return [ele]
def Flatten_lv3 (lst):
    return [i for sub_lst in lst for i in sub_lst]
def AllElementsOfCategoryInView(categories):
	categories = ToLst(categories)
	allcates = doc.Settings.Categories
	valid_cate = []
	alleles = []
	for cate in allcates:
		for category in categories:
			if cate.Name == category:
				valid_cate.append(cate)
	for cate in valid_cate:
		alleles.append(FilteredElementCollector(doc,view.Id).OfCategoryId(cate.Id).WhereElementIsNotElementType().ToElements())
	return Flatten_lv3(alleles)
def IntersectionPlaneAndLine(plane,line):
    planePoint = plane.Origin
    planeNormal = plane.Normal
    lineStart = line.GetEndPoint(0)
    lineEnd = line.GetEndPoint(1)
    lineDirection = (lineEnd - lineStart).Normalize()
    # Check if the line is parallel to the plane
    # If yes, return None
    if planeNormal.DotProduct(lineDirection) == 0:
        return None
    lineParameter = (planeNormal.DotProduct(planePoint) - planeNormal.DotProduct(lineStart)) / planeNormal.DotProduct(lineDirection)
    return lineStart + lineParameter * lineDirection
def IsPointOnLine(point,line):
    # If a point C is on a line, it will be between start point(A) and end point(B) of a line
    # AB = AC + CB
    lineLength = lineStart.DistanceTo(lineEnd)
    startToPoint = lineStart.DistanceTo(point)
    pointToEnd = point.DistanceTo(lineEnd)
    if lineLength == startToPoint + pointToEnd:
        return True
        return False
def GetZCoordinate(point):
    return point.Z
def SortPointByElevation(points):
    return sorted(points, key=GetZCoordinate)
def SortPointByLineDirection(line,lstPoint):
    direction = line.Direction
    vectorZ = direction.Z
    sortedPoints = SortPointByElevation(lstPoint)
    if vectorZ > 0:
        return sortedPoints
        return list(reversed(sortedPoints))
def SplitPipeByPoint(pipe,pts):
    ele = []
    with Transaction(doc,'Break Curve') as t:
        t.Start()
        result = []
        for pt in pts:
            try:
                ele.append(DB.Plumbing.PlumbingUtils.BreakCurve(doc,pipe.Id,pt))
            except Exception as er:
                result.append(er)
        ele.append(pipe.Id)
        result = [doc.GetElement(Id) for Id in ele]
        t.Commit()
    return result
def SplitDuctByPoint(duct,pts):
    ele = []
    result = []
        t.Start()
        for pt in pts:
            try:
                ele.append(DB.Mechanical.MechanicalUtils.BreakCurve(doc,duct.Id,pt))
                result.append(er)
        ele.append(duct.Id)
        t.Commit()
    return result
def ClosestConnectors(ele1, ele2):
	conn1 = ele1.ConnectorManager.Connectors
	conn2 = ele2.ConnectorManager.Connectors
	dist = 100000000
	connset = None
	for c in conn1:
		for d in conn2:
			conndist = c.Origin.DistanceTo(d.Origin)
			if conndist < dist:
				dist = conndist
				connset = [c,d]
	return connset
def CreateUnionFitting(ele1,ele2):
    connectors = ClosestConnectors(ele1,ele2)
    result = []
    with Transaction(doc,'Create Union Fitting') as t:
        t.Start()
        try:
            result.append(doc.Create.NewUnionFitting(connectors[0],connectors[1]))
            result.append(er)
        t.Commit()
    return result
#----------------------------Main Logic-----------------------------------------
# Select duct and pipe
filterEle = SelectionFilter(["Ducts","Pipes"])
refEle = selection.PickObjects(ObjectType.Element, filterEle, "Select Model Elements")
selectedEle = []
for sublst in refEle:
    selectedEle.append(doc.GetElement(sublst))
eleLine = []
for ele in selectedEle:
    line = ele.Location.Curve
    eleLine.append(line)
# Get all levels in view
allLevels = AllElementsOfCategoryInView("Levels")
levelElevations = [level.Elevation for level in allLevels]
# Create planes from levels
planeLst = []
z_axis = XYZ(0,0,1)
for elevation in levelElevations:
    plane = Plane.CreateByNormalAndOrigin(z_axis,XYZ(0,0,elevation))
    planeLst.append(plane)
# Get intersection points between line and plane
intersectionPoint = []
for line in eleLine:
    sublst = []
    for plane in planeLst:
        point = IntersectionPlaneAndLine(plane,line)
        if IsPointOnLine(point,line):
            sublst.append(point)
    intersectionPoint.append(SortPointByLineDirection(line,sublst))
#----------------------------------Split Vertical Segment-----------------------------------------------------------------
with TransactionGroup(doc,'Split Vertical Segment') as tg:
    tg.Start()
    newEles = []
    newEles2 = []
    for ele,sub_lst in zip(selectedEle,intersectionPoint):
        if isinstance(ele,Autodesk.Revit.DB.Plumbing.Pipe):
            newEles = SplitPipeByPoint(ele,sub_lst)
            newEles2 = newEles[1:]
            newEles = SplitDuctByPoint(ele,sub_lst)
        for ele1,ele2 in zip(newEles,newEles2):
    tg.Assimilate()
(some module settings and it should also work in dynamo)
