Revit Batch Processor - BIM360 Cloud Models - File Paths
Hi, I would appreciate help with finding away to get multiple models file paths from cloud workshared models on BIM360 to feed to BVN Revit Batch processor to run Dynamo / Python scripts.
I understand, according to RBP Github, the file paths need to be in the below formats
The format for specifying a cloud model in the Revit file list is:
  • <Revit version> <Project Guid> <Model Guid>
  • Note: these three components must be separated by space(s) (not tabs!).
  • e.g. 2020 75b6464c-ba0f-4529-b049-0de9e473c2d6 0d54b8cc-3837-4df2-8c8e-0a94f4828868
As am not a Forge user, wondering what would be the best/fastest approach to get the paths according to the above formats.
Appreciate your prompt help!
Hi @MOhie,
I had the same problem. Have you had more information on how to solve it?
You could try Bird Tool’s-Dynamo Multiplayer. its similar to BVN batch processor but can run for BIM 360 files ( as well as local files). It gets installed like a plugin for Revit, just launch it in any rvt file & select the required BIM 360 files , select the desired dyn file & your are good to go.
hope that helps
Get the Revit version with this
element = UnwrapElement(IN[0])
app = doc.Application
version = app.VersionNumber
OUT = version
Get the project ID with this
import sys
import clr,System
clr.AddReference('RevitAPI')
OUT = doc.GetCloudModelPath().GetProjectGUID()
Get the file id with this
import sys
import clr,System
OUT = doc.GetCloudModelPath().GetModelGUID()
Concatonate all that and you have a line for BVN
