Hello everyone, I try to create script for spot coordinate at adaptive placement point but it error and i don’t know what i wrong.
I have created script spot coordinate for structural framing and it work.
Thank you for your recommend.
i would start from here:
“If the reference is not valid or the point cannot be projected to reference correctly, an exception will be thrown.” - revit doc
I try doing it for a while i still don’t know how to make it work. can you help me for find correct way? please.
im away from rvt these days but to get more help, i suggest u post a sample test case here, or a copy of the adaptive component at least. and there’s actually a posting option for formatted code which would be nice to gain more help.
op’s script, for copy-n-paste:
doc = DocumentManager.Instance-CurrentDBDocument
element = UnwrapElement(IN[0])
result = []
#Do some action in a Transaction TransactionManager.Instance.EnsureInTransaction(doc)
for e in element:
refPoint = AdaptiveComponentInstanceUtils.GetInstancePointElementRefIds(e)
for rep in refPoint:
rp = doc.GetElement(rep)
ref = Reference(rp)
sp = rp.Position
x = sp.X
y = sp.Y
z = sp.Z
bend = XYZ(x+5, y+5, z)
end = XYZ(x+10, y+10, z)
spc = doc.Create.NewSpotCoordinate(doc.ActiveView, ref, sp, bend, end, sp, False)
result.append(spc)
OUT = result
