Does a node exist to grab all elements in Revit in lieu of all elements by category?
In the node element types I believe there is a choice for element types. From there you can do
element types> Select all elements of type
So that would be all elements by type, correct? I’d like to select all of the geometry in my Revit model with a single node if possible.
A better solution may be to go into a 3d view and use this node.
You could select all elements by level then flatten the list to have a list of all elements in the project.
