Hello everyone,
I would like to assign the correct Analytical Cross-Section Rotation to all of the columns in my Revit 2023 model but when I run the Analytical Automation to assign the cross-section rotation it defaults to every column to 0.00° which is incorrect. The column rotation varies throughout the project. Has anyone else experienced this issue and is there a fix to assign the correct cross-section rotation?
Thank you!
Analyze tab>Analytical Automation>Physical to Analytical for Buildings>Select physical elements
then select all column in a 3D view and click Run.
