I can´t find any method to retrieve the geometry of Autodesk.Revit.DB.PropertyLine after I collected the Revit elements via
PropertyLines_collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_SiteProperty).WhereElementIsNotElementType().
Any hint?
Assuming you’re in Python, what have you tried?
Does geo = [pl.get_Geometry(Options()) for pl in PropertyLines_collector] work?
Thanks Jacob. One solid step forwards. Yes, I´m in Python. I had tried this with the wrong syntax. Now I get a Autodesk.Revit.DB.GeometryElement, how to convert it to the constituent array of curve?
Look at what you can do with the element. Try OUT = dir(geo[0]) to see what you have for options.
that´s where I get stranded…I see no conversion method available
__subclasshook__
__str__
__sizeof__
__setattr__
__repr__
__reduce_ex__
__reduce__
__new__
__ne__
__iter__
__init__
__hash__
__getattribute__
__format__
__exit__
__eq__
__enter__
__doc__
__delattr__
__contains__
__class__
Visibility
ToString
ReleaseUnmanagedResources
ReleaseManagedResources
ReferenceEquals
MemberwiseClone
MaterialElement
IsReadOnly
IsElementGeometry
Id
GraphicsStyleId
GetType
GetTransformed
GetHashCode
GetEnumerator
GetBoundingBox
Equals
Dispose
Closest I thought was geo.GetType() but it returns Autodesk.Revit.DB.GeometryElement.
Is there a way to get the primitive geometry? I suppose it should be an array of curves
Hi
you need to iterate on the GeometryElement
There are some examples in the forum
https://forum.dynamobim.com/search?q=get_Geometry%20%40c.poupin
indeed! iterating a RevitElement makes the RevitObject available so that the geometry can be extracted as a primitive (in my case, with Rhino.Inside). Thanks a lot!
Below the correct code
if PropertyLines_collector.GetElementCount() == 0:
msg = "MISSING ! at least one PropertyLine is needed"
show_error(msg)
for propLine in PropertyLines_collector:
propLine_element = propLine.get_Geometry(Options())
lines = []
#iterate to resolve the enumerable RevitElement into RevitObject
for propLine in propLine_element:
#get the RevitObject geometry
lines.append(GeometryDecoder.ToCurve(propLine))
