Hi
Anybody have a script for level of reservation on wall on REVIT 2020 ?
first, not sure what âlevel of reservationâ means so some clarification might be needed on this, secondly (and maybe more important) please see the following FAQ forum topic: How to get help on the Dynamo forums
Thanks for your answer.
On REVIT 2018, i have no problem to have a label of reservation with width, height and level NGF, due to a script of dynamo.
When i passed to REVIT 2020, with the same script of dynamo, the level NGF being blocked at 00.00, and is not at 159.70.
Is there a difference between dynamo on REVIT 2018 and REVIT 2020 ?
Arase infĂ©rieure rĂ©servations.dyf (13.9 KB) Arase infĂ©rieure rĂ©servations.dyn (6.1 KB) ECO_RĂ©sa Verticaux_Ă_PB.rfa (396 KB) ECO_Etiquette_RĂ©sa_Ă.rfa (276 KB)
translated by moderator. Original post below the line
Hello @Chris.V
I also use dynamo for the edges and axes of the reservations.
I donât know if you got an answer or a solution for your script, however, on the 2021 version of Revit, the elevation parameter is now called (in French) Elevation versus level.
maybe this can solve your problem.
Iâm taking inspiration from your script to also create a dynamo script against my shared settings, however, in your reservation family the lower Arase setting is not physically materialized.
maybe this is another avenue of investigation for your error message.
also nodes sometimes change names between multiple package updates, I get the impression âŠ
if you can just explain how you resolved your concern, so that you can help me move forward as well.
Thank you and good day
original post below
Bonjour @Chris.V
jâutilise Ă©galement dynamo pour les arases et axes des rĂ©servations.
je ne sais pas si tu as eu une rĂ©ponse ou une solution pour ton script, cependant, sur la version 2021 de Revit, le paramĂštre Ă©lĂ©vation sâappelle dĂ©sormais (en français) ElĂ©vation par rapport au niveau.
peut ĂȘtre que cela peut solutionner ton problĂšme.
je suis en train de mâinspirer de ton script pour crĂ©er Ă©galement un script dynamo par rapport Ă mes paramĂštres partagĂ©s, cependant, dans ta famille de rĂ©servation, la paramĂštre Arase infĂ©rieure nâest pas physiquement matĂ©rialisĂ©.
peut ĂȘtre que câest une autre voie dâinvestigation pour ton message dâerreur.
Ă©galement les noeuds changent parfois de nom entre plusieurs mises Ă jour de package, jâai lâimpressionâŠ
si tu peux juste expliquer comment tu as rĂ©solu ton souci, afin de mâaider Ă avancer Ă©galement.
merci et bonne journée
@mathieu.bernard the official forum language is English. This is a requirement in order to make search work. Please translate posts via online translation service as I did above prior to posting in the future.
Hello
Sorry, my internet browser has translated
the page automatically, I didnât realize it.
I will be careful next time
thanks
Or use the French forum
