Replace true by condition, how?
i create some loops for booleans i want to replace them by a string, but how?
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#functions
def tolist(x):
    if hasattr(x,'__iter__'): return x
    else: return [x]
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Doors)
all_elements = collector.WhereElementIsNotElementType().ToElements()
onHand = [ i.HandFlipped for i in all_elements] # is LE
onFace = [ i.FacingFlipped for i in all_elements] # is LE
bothFaceHand = [ i.FacingFlipped and i.HandFlipped for i in all_elements] # is RE
bothHandFace = [ i.HandFlipped and i.FacingFlipped for i in all_elements] #  is RE
#rest is RE
_onHand = [p for p in onHand if i.Replace(True,"LE")]
OUT = _onHand
Replace does not work
grafik
KR
Andreas
Is this what you are trying to do?
[True for p in onHand if p == "LE" else p]
or
["LE" for p in onHand if p == True else p]
@Mike.Buttery
grafik
idea is to create a “flipmatrix” so you can see if door is correct string value vs visual representation!
KR
Andreas
So my understanding is that if facing and handing are different (True / False | False / True) = RE
This is an XOR logic which would imply a comprehension like this
["LE" for i in all_elements if i.FacingFlipped == i.HandFlipped else "RE"]
True/True and False/False evaluate as True whereas True/False and False/True evaluate as False
