I have a list of lists that contain names, based on those names I want to replace them with different text. I have multiple search terms. That seems to be working, however I can’t get the single item in teh list 2 to replace all true items in list 1. The null items in my out list should be THRD.
@Evan.Pond Would a python solution work?
OUT = [[IN[2] if item in IN[1] else item for item in list] for list in IN[0]]
@Evan.Pond If not, try this:
I’ve used == node but you will get the same result with the String.Contains node as well.
@Evan.Pond Yes, sir. It is possible to ignore the case.
Try this:
toNestList = lambda x: x if any(isinstance(i, list) for i in x) else [x]
OUT = [[IN[2] if item.lower() in map(str.lower,IN[1]) else item for item in list] for list in toNestList(IN[0])]
Thanks for the help, this gets me what I need.
@Evan.Pond It is still doable.
The one on top is case-sensitive and the bottom one is case-insensitive.
Using the case-insensitive one may also lead to some unexpected replacements. e.g. It replaced Br in Brass
See which script works best for you.
Case-sensitive script:
def replace_words(strText):
for searchWord in IN[1]:
strText = strText.replace(searchWord, IN[2])
return strText
OUT = [[replace_words(item) for item in list] for list in toNestList(IN[0])]
Case-insensitive script:
import re
pattern = re.compile(searchWord, re.IGNORECASE)
strText = pattern.sub(IN[2],strText)
return strText
That you so much for all your help, I should have been more clear.
When a line item has anything in the search list I want the whole thing to be replaced.
I am inputting a list of fittings and I want to output the list as to the pipe end prep needed:
@Evan.Pond Here you go
OUT = [[IN[2] if any(st.lower() in item.lower() for st in IN[1]) else item for item in list] for list in toNestList(IN[0])]
