I’m trying to rename multiple groups at same time with excel sheet but i’m getting this error. is there any way to resolve this error?
PS: all model groups have only one instance
The warning from the node is telling you that you are feeding a String (Text) which is not correct. The parameter value needs to be a Type, but you are feeding the name of a Type…
You’ll need to generate a list of Types which aligns to the list of names…
There might be a node, get type by name? but I’m not sure…
Otherwise using a dictionary would be best? Get all the Types, make a dictionary where the Key is the name, then use your list of Names to pull them out in the correct sequence?
Hope that helps,
Mark
hello sir,
I tried get type by name but it’s not working in my case.
also can you tell me how to feed correct values to the node. I’m still learning dynamo so don’t know how to do it. ![]()
could you upload a stripped rvt file with these groups and i will take a look…try to move the flattern node to after your "modelgroup by name
YES SURE
Rename Group.rvt (4.4 MB)
Rename Group.xlsx (7.9 KB)
Rename Groups.dyn (19.4 KB)
Thanks a lot sir!!! it works
you saved a lot of time of my works.
You are welcome ![]()
