Hi all,
I am trying to rename the print set though dynamo and I came across that the API allows it. Can someone please guide me how to do it?
I have 50 print sets (sheet sets) and I want to rename it without losing the filter for browser organisation.
The way I was doing it before was creating a new one and adding the existing sheets into it with a new name but I kept loosing the browser org filter.
Can some please assist.
Thank you so much
I believe you need to get the Print Manager class to focus on it first, which I’m fairly sure this code can do if doc is current document, you have dependencies available and you have your sheet set as an object:
printMan = doc.PrintManager
viewSS = printMan.ViewSheetSetting
viewSS.CurrentViewSheetSet = yourSheetSet
viewSS.Rename("New name")
Thanks Gavin for the response,
I tried your way
Blockquote
import sys
clr.AddReference(“RevitAPI”)
view_sheet_sets = IN[0]
New_name = IN[1]
for view_sheet_set in view_sheet_sets:
print_manager = doc.PrintManager
viewSS = print_manager.ViewSheetSetting
viewSS.CurrentViewSheetSet = view_sheet_set
viewSS.Rename(“New_name”)
OUT = success
Blockquote
but it showed me an error,
Am I missing anything?
I have a fixed a couple of things which might have caused an issue, here is the code but I got a different error this time.
Blockquote
import sys
viewSS = IN[0]
New_name = IN[1]
for view_set in viewSS:
view_sheet_setting = print_manager.ViewSheetSetting
view_sheet_setting.CurrentViewSheetSet = view_set
view_sheet_setting.Rename(New_name)
OUT = “View sheet set(s) renamed successfully.”
Blockquote
I think I fixed it, maybe if someone can share a better way to do it.
Blockquote
import sys
view_sheet_set_ids = IN[0]
new_name = IN[1]
Start a new transaction
for view_sheet_set_id in view_sheet_set_ids:
view_sheet_set = doc.GetElement(ElementId(view_sheet_set_id))
view_sheet_setting.CurrentViewSheetSet = view_sheet_set
view_sheet_setting.Rename(new_name)
Commit the transaction
Blockquote
I’ve tidied up a slightly different take here which can handle list of sheet sets + list of new names, and also accounts for skipping duplicate names and can handle change of case scenarios:
# Boilerplate text
clr.AddReference("RevitAPI")
# Current doc/app/ui
# Define list/unwrap list functions
def tolist(input):
result = input if isinstance(input, list) else [input]
return result
def uwlist(input):
return UnwrapElement(result)
# Preparing input from dynamo to revit
sheetSets = uwlist(IN[0])
newNames = tolist(IN[1])
# Get names of viewsheetsets
allSheetSets = FilteredElementCollector(doc).OfClass(ViewSheetSet).ToElements()
allSetNames = [ss.Name for ss in allSheetSets]
# Do some action in a Transaction
# Get the print manager and sheet settings
printman = doc.PrintManager
printman.PrintRange = PrintRange.Select
settings = printman.ViewSheetSetting
results = []
# For each set and name
for ss,nn in zip(sheetSets,newNames):
# Make sure it isn't reserved
if nn not in allSetNames:
settings.CurrentViewSheetSet = ss
# Temporary rename in case it is same but different case
tempName = "TEMP_" + nn
settings.Rename(tempName)
# Actual rename
settings.Rename(nn)
results.append(True)
results.append(False)
# Preparing output to Dynamo
OUT = results
Ah that’s great.
Thanks Gavin
