Remove list from list for curve
Does anyone know how to remove a list from another list for curves?
The List.SetDifference node seems only fit for numbers and points, but it does not work for curves.
Thanks a lot.
Try this
Capture
Py Script by @Nick_Boyts can be found here
https://forum.dynamobim.com/t/help-remove-duplicates-accross-list-of-list/38212/10
Thank you for your help. Your code work perfectly with numbers but it does not work for lines or curves. Is there any ways could be done for curves?
Hi @htmokac @AmolShah
Here is another possible way:
OUT = sorted(set(IN[1]) - set(IN[0]))
Edit: Yes i noticed the same Line gives 1st List. I’m away now from my PC. I will get back to this soon.
This one works for all types:
OUT = IN[0][len(IN[1]):]
Thanks. However, it seems not working if 2 lists are not start with the same point.
It does not work as well if the list is in different orders.
@htmokac Are you looking for this?
@Kulkul that exactly what I looking for. May I know how can you do it?
@htmokac convert to strings → Check if IN[0] is equal to IN[1] which will give you booleans → Filter false.
@Kulkul Thanks again. I have tried what you suggested. However the output will change to strings instead of lines/ curves. Further operations, like forming walls, are not allowed.
@htmokac Could you drop here your python code?
@Kulkul
OUT = set(IN[0]) - set(IN[1])
@Kulkul It works by using your flow. Thank you very much.
