Extract common values from both lists
hello.
is it possible to make a list out of these two only showing the curves common in both list. if yes how?
Definitely @maheeramurad - You can use List.SetIntersection :slight_smile:
not working in case of curves
Ah, strange. This usually works.
As a workaround, you can use a String from Object node and the comparison will work.
