Remove element from electrical circuit
I’m trying to remove an element from electrical circuit using the RemoveFromCircuit method and I’m getting the error - “RemoveFromCircuit() takes exactly 2 arguments (1 given)”
the argument should be an elementset of the components. What is the second argument?
Is there another method to remove an element from an electrical circuit?
Hello @ronit.barakiva, could you share your files to check them?
I was looking at my files again today with fresh eyes and it’s working :slight_smile:
Enable Python support and load DesignScript library
#import Revit Nodes
clr.AddReference(‘RevitNodes’)
#import RevitAPI
clr.AddReference(‘RevitAPI’)
from Autodesk.Revit.DB.Electrical import *
#import DocumentManager and TransactionManager
The inputs to this node will be stored as a list in the IN variables.
ElectricalComponents = UnwrapElement(IN[0])
ElectricalCircuits = UnwrapElement(IN[1])
ElecSet = ElementSet()
Place your code below this line
for element in ElectricalComponents:
ElecSet.Insert(element)
for circuit in ElectricalCircuits:
circuit.RemoveFromCircuit(ElecSet)
Assign your output to the OUT variable.
OUT = ElectricalCircuits
#For anyone who sees this in 2021:
#Enable Python support and load DesignScript library
#import Revit Nodes
#import RevitAPI
clr.AddReference('RevitAPI')
#Place your code below this line
Dynamo script for removing a selection of elements from any circuits they are assigned to. Working in 2025.
Remove Electrical Fixtures from Circuit.dyn (13.7 KB)
